konica minolta 658e bad copy
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: konica minolta 658e bad copy
    Originally posted by brent
    if you get a chance would you look at my last comment to you? are you replacing the scanner ccd onlly or the mirror assy as well? I come up with a different part number from the 658e series to the 364e series.. is it the same? I will s wap this out but trying to figure out what parts.. only the ccd or both.. thanks again so much
    brent
    Change the Entire scanner unit 4 /4E series works on the 8 series
    • brent
      • Nov 2008
      • 1212
      ok I see. the w hole scanner lol if a konica minolta 364e unit works then I will try it.. I bet it goes faster when you do it more then once.. it looks like a ton of stuff to remove lol thank you
      brent
      • brent
        • Nov 2008
        • 1212
        ok we had a brand new konica minolta 364e that had lower end damage.. so I was able to get the scanner off it
        I will take it and replace it next week with the damaged 368e looks like it will be a direct fit. even though some of
        the wires are a different color but youve said you have done this.. will I need to do any functions when its all replaced?
        or just replace and start copying?
        thanks again byronf
          • 23006
          #19
          I haven't actually done this swap, but I would suspect that the scanner motor will be regulated by the engine, scanning at whatever speed the engine calls for. Pulse motors are very flexible that way. =^..^=
          • brent
            • Nov 2008
            • 1212
            #20
              • 23006
              #21
              Many of the small Sharps required the whole DF removed, then scanner removed, then flipped over and a dozen or so screws removed to split the scanner body, then ... ta-daa! Clean the scanner optics!
              It didn't happen very often. I may have been the only tech at that company to clean mirrors. =^..^=
              • tsbservice
                Field tech
                • 8003
                #22
                Analog days that would be something like 2 screws and voila
                They seem to hold better now but occasionally A4 scanner bed must be open not ideal job.
                  IDEAL? I'd rather stroll thru hell with petrol shorts on, on some brands/models.
                  [emoji1787]
                  • Zesti
                    • Jun 2009
                    • 308
                    #24
                    The scanner is pushed down from front left corner... have seen this problem with quite a few times on older Di series and even BH501 series and even C450... just lift from front left corner andf I hoper it will be good...
                    • brent
                      • Nov 2008
                      • 1212
                      #25
                      ok well bad news. I swapped the scanner out from a konica minolta bizhub 364e and it went into a c 6756 code.. so now its back at the office for me to troubleshoot when I get time.. which may be next week with all the work going on.. any ideas on what went wrong? I suspect the main board on the scanner wasnt compatible. easy swap now that it is all moved over. just looking for thoughts. thanks
                      brent
                      • tsbservice
                        Field tech
                        • 8003
                        #26
                        brent
                        For 6756 code try to load latest FW.
                          • 23006
                          #27
                          +1
                          • brent
                            • Nov 2008
                            • 1212
                            #28
                            well today I installed the latest version of firmare it did not fix it.. I am starting to think the new scanner from a 364e was not compatible? I took the unit back apart thinking I may have forgotten a wire or something. any more ideas? I may put the old one back on just to feed my curiosity.. or do I need to swap a board out and leave the scanner with current optics? thanks for all the advice
                            brent
