C554e toner refill
  • Amrss
    • 46
    C554e toner refill
    Hello everyone,
    is it possible to refill the konica minolta c554e cartridges with toner specific for press machines like the 1070 or 3070 ( this one specifically Konica Minolta TN619 Toner Set for bizhub PRESS C1060 C1070 Part Number: TN619 4-Pack ), would I face any problems if I did that ?
    I want to do that as it can be a lot cheaper than buying the genuine toner specific for the c554e machine.
    Re: C554e toner refill
    Originally posted by Amrss
    Hello everyone,
    Compatible toners can cause all sorts of problems from CQ to premature failure of parts.
    Do what you want but I'd stear clear.
    • Amrss
      • 46
      sorry but, CQ stand for ?
      would those problems occur even if I refilled with genuine c3070 toner ?
        CQ = copy/print quality.
        As far as I know they do not sell bulk toner powder.
        • Amrss
          • 46
          If I emptied genuine toner cartridges specific for the c3070 in the c554e cartridges, would that cause any problems ?
          Is the toner material the same for both machines?
          • patrickjlc
            • Feb 2015
            • 225
            I had issues with refilled/ aftermarket toners. You might save some money on the toner, but drums are expensive if messed up with non original toner, learned that the hard way....
            Sent from my motorola one 5G UW using Tapatalk
            • Amrss
              • 46
              Would those problems still happen even if I refilled with genuine toner specified for a konica machine other than the one I have ?
              • copyman
                Owner / Technician
                • Sep 2005
                • 4788
                Some of the toner is same, for instance all the 4 series is same. I wouldn't use a different series toner. Like the other poster said why ruin the drums with wrong toner. Forget about the drums, what about contaminating the developer units with wrong toner, dev units cost $500+ each!
                • Amrss
                  • 46
                  Got your point, would be interested to hear what others say or if anyone tried this
                  Thank you so much sir
                  • emujo2
                    • Mar 2017
                    • 1579
                    The very fact that there are 100 different toner bottles out there for the current fleet of machines drives me f'ing nuts..One bottle to rule them all!!!..Of course, production and KM branded devices are going to be different, and I understand the corporate level need to keep out knock off supplies as this affects their bottom line. IMHO if you are having to resort to filling up toner with the left overs from other devices you are probably not going to last much longer. E
                    • allan
                      RTFM!!
                      • 5462
                      The Materials Safety Data Sheets shows that the toner composition is not the same.
                      TN619 contains organic pigment and there are too many differences.
                      Here compare the MSDS for yourself.
                      MSDS TN512K.pdf
                      MSDS TN619K.pdf
                      I always check this first before using other toner. But does not mean that it will not work.
                      Whatever
                      • Amrss
                        • 46
                        Appreciate the reply sir
                        • Amrss
                          • 46
                          Here compare the MSDS for your self.
                          MSDS TN512K.pdf
                          MSDS TN619K.pdf
                          I see, since there are differences I don't think it's worth it to risk damaging the drum units or the developer units
                          Thank you so much
                          • Zesti
                            • Jun 2009
                            • 312
                            Hello everyone,
                            It will give excellent result... provided toner is OEM..
                            Be carefull not to refill in humid environment...
                            • Amrss
                              • 46
                              Thank you for your reply sir
                              Have you tried doing this on konica machines and what were the models used?
