C654e Fs534SD
  • big jase
    • Jul 2008
    • 136
    [Jamming] C654e Fs534SD
    Hi
    Strange one, jams 72-19 in finisher but only when doing a double-sided job and only when a full darker print is on the 2nd side
    If at First you don't succeed remove all evidence of ever trying!
  • Albonline
    • Sep 2008
    • 1135
    Re: C654e Fs534SD
    Originally posted by big jase
    Hi
    check the fans and filters in the cooling system, sounds like toner may be sticking to things in the inversion/exit units.
    • tech51
      • 846
      Re: C654e Fs534SD
      Hi
      A colleague of mine had something similar. He physically cleaned all the sensors with alcohol rather than just blowing them out.
      The customer was using originals with a dark background.
      Worked for him!
      • allan
        RTFM!!
        • 5459
        Re: C654e Fs534SD
        Paper curl issue? Try dropping the fuser temp to see if that helps.
        Whatever
        • blinxwap
          • Jun 2020
          • 80
          Re: C654e Fs534SD
          Hi
          Clean or replace the exit/entrance sensor on the finisher
          Sent from my SM-A725F using Tapatalk
