machine showing wrong installation of DV unit magenta in c224e
  • vijaysharma
    • Sep 2008
    • 61
    [Error Code] machine showing wrong installation of DV unit magenta in c224e
    Hi,
    I am facing a problem in bizhub c224e that the machine is continuously displaying the message that wrong Magenta developing unit is installed. What I have done is as follows:-
    1) Reinstall the magenta unit correctly, But it still not clear.
    2) Replaced the magenta developing, But it still not clear.
    3) Replaced the FRB board, But it still not clear.
    4) Replaced the PRCB Board, But it still not clear.
    5) Replaced the wiring related to it, But it still not clear.
    6)Checked and replaced all the switches, But it still not clear.
    Even after doing a lot, the machine only displaying this error continuously.
    Has anyone faced this problem.
  • tsbservice
    Field tech
    • 8053
    Re: machine showing wrong installation of DV unit magenta in c224e
    Are you using original developer units as color ones are diabolical expensive or use just developer chips?
    • allan
      RTFM!!
      • 5462
      Will also happen if you install a K dev chip on a color unit.
      Try to do a system error clear under initialization.
      Whatever
      • Tech Helpdesk
        • Jul 2015
        • 112
        We replace the colour developer units with black ones.
        We fit the old colour TCR board to the new black developer unit and then use the Developer Reset Tool to reset and start the dev charge cycle.
        When this is complete we go into service and produce halftones at 200 for the colour that has the black dev unit fitted to, this way the correct colour will flush through after about 40 sheets A3.
        We never use 'aftermarket' chips anymore as the quality is unpredictable and we used to get errors like you are having.
        • emujo2
          • Mar 2017
          • 1579
          Yeah, I'm pretty sure this is your problem. Put the right parts in..E
          • allan
            RTFM!!
            • 5462
            Been doing the same. I replace the fuses on the old chips to get it to reset.
            Whatever
            • Brett GS
              • Jun 2013
              • 154
              Alan what rating fuses are you using?
              Where you getting them from?
              • allan
                RTFM!!
                • 5462
                Brett i am not sure. Around 60mA slow blow fuses comes to mind but this fuse is an ICP style surface mount fuse. Been modifying TN512 to work as TN321 as its cheaper and one less stock item to carry. BH554 to BH364. That leaves you with the chips that comes off the toner bottle. The fuses on there are the same and that is what i have been using.
                Should be able to get them online somewhere but never made an effort to buy them.
                Whatever
                • vijaysharma
                  • Sep 2008
                  • 61
                  Yes I'm using OEM magenta DV unit,
                  • REGSIS
                    • May 2016
                    • 435
                    Nope, it's the same! Only wiring is of different colour and lenght.
                    • copier tech
                      • 8200
                      Originally posted by vijaysharma
                      Hi,
                      Have you updated the firmware?
