C-258
  • CP-1015
    • Nov 2020
    • 323
    [Error Code] C-258
    After booting C-258 show's the following screen:
    Enable password rules and set administrator password to increase security. Settings can be configured on the quick security setting screen."
    password rules are activated and admin pw as usal. Printing and copying without issue. What's wrong?
    Thanks advanced.
  • Synthohol
    Certified Konica Expert
    • 5871
    Re: C-258
    it appears the admin password is blank?
    • CP-1015
      • Nov 2020
      • 323
      Re: C-258
      No, admin pw as usal.
      • B0265
        • Jan 2007
        • 718
        Re: C-258
        Check this setting:
        Administrator Settings - Security Settings - Quick Security setting - Security Warning Display Setting
        • CP-1015
          • Nov 2020
          • 323
          Re: C-258
          Originally posted by B0265
          Check this setting:
          Thanks, it helped. But I wonder about the reason. Why is there a warning for perfekt admin password?
            • 14899
            Re: C-258
            I'm just curious, and it is likely unrelated but were you setting up/ or is Bizhub Secure already set up?
            • CP-1015
              • Nov 2020
              • 323
              Re: C-258
              I don't know. I have bought it with others and only tested it.
              • tsbservice
                Field tech
                • 8032
                Re: C-258
                Those are common with all new i-series machines as security precautions. Even latest IT5 machines have it. Nothing wrong just follow B0265 advice and turn off IP filter and password rulles.
