Scan preview screen
  • mike_hartung
    • 39
    Scan preview screen
    I just repaired a Bizhub C368 with a code C-D011 error. I installed the recovery tool GXX-A8, then the preventive firmware GXX-B0. Also did a physical and logical format of the hard drive. The machine is working fine except now when scanning to e-mail a preview screen come up showing all the scan settings and says something about broadcast settings. If you press the scan button at the bottom of this screen the machine will send the scan just fine. Before I did the repair this extra preview screen never came up and I have never seen it on any other machine. How do I shut off this extra preview screen? I have scrolled through the settings and have not found anything. Help please the customer does not want this extra screen when they scan.
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: Scan preview screen
    I think it's called "preview before processing"
    It can be turned off
    • mike_hartung
      • 39
      Do you know how to turn it off? Is it in admin mode settings somewhere?
      • tsbservice
        Field tech
        • 8020
        I would play with this setting:
        Utility]
        [Administrator Settings]
        [System Settings]
        [Preview Settings]
