Blank Line Problem
  • Omar Faris
    • Oct 2017
    • 15
    Blank Line Problem
    Hello,
    So the problem is that a blank line appear on paper, the orientation of papers in tray is landscape, this line does not appear always in the same place, also it appears only one time for each page, you can see the picture attached with this post.
    Machine Model = Bizhub 350
    Thanks.
    Re: Blank Line Problem
    Originally posted by Omar Faris
    Hello,
    Thanks.
    What model machine?
    • rrrohan
      • Sep 2011
      • 1977
      prob a bug walking around over laser unit
      • Omar Faris
        • Oct 2017
        • 15
        What model machine?
        konica minolta bizhub 350
        • rrrohan
          • Sep 2011
          • 1977
          i wasnt joking about the bug btw ive had baby cockroaches cause this
          • Omar Faris
            • Oct 2017
            • 15
            So to fix this i need to clean laser unit or what?
            • Manikandan T
              • Sep 2019
              • 14
              What model machine?
              i faced it lot of times Check the Mag roller toner and developer not forming some times dust in developer use a business card and swipe left to right between magroller and develop/doctor blade you can see the magic!!!!!
              • rrrohan
                • Sep 2011
                • 1977
                void lines are when a laser fails to hit the drum, the fact its moving suggests the thing blocking it is moving as well which is normal a bug. in my experience a moving fault is a moving bug. mice are dumb and will normally get electrocuted but roaches are survivalists
                • Manikandan T
                  • Sep 2019
                  • 14
                  i faced it lot of times in 250 and 362
                  you are using A4 or A4R
                  if using A4 Try This
                  • tsbservice
                    Field tech
                    • 7972
                    Agree. Actually it's better to empty developer unit on clean sheet of A3 paper, clear doctor-sleeve gap and screen developer and toner material from debris or caked pieces then poor the mix back into developer unit.
                      +1
                      • Zesti
                        • Jun 2009
                        • 308
                        Quite applausable....
                        Check magnet roller for that or any missing lines....if clear.....check for cockroaches...
                        • rrrohan
                          • Sep 2011
                          • 1977
                          Faults are called bugs for a reason lol
                          Sent from my Pixel 4 XL using Tapatalk
                          • Toxic
                            • 697
                            Lol agreed, it could be the problem for real.
                            Recently have similar problem on C227, few void white lines on black, replaced another drum, checked developing unit, lines still there.
                            When i remove laser i found dead-melted spider on laser glass for black
                              • 22997
                              Either one of these are likely possibilities. Based on your samples, I'm leaning towards the first one. Either a toner rock or some other foreign contaminant collected under the doctor blade will account for this. Small contaminants tend to wedge in, under the doctor blade, so they stay still. Larger contaminants can float around and show up in different places on the image. =^..^=
