Toner compatibility
  • emujo2
    • Mar 2017
    • 1580
    [Misc] Toner compatibility
    Under the current conditions I would like to start a compatibility list of KM toners...
    TN-014 will work for TN-016, TN-017
    TN-322 will work in any B&W or color e series. you can either swap the caps or put the toner in the old bottle
    Looking for positive results for any production color, or 8/I series that you may have found. TIA E
  • suomi
    • Oct 2008
    • 152
    Re: Toner compatibility
    Katun Performance™ Universal Toner for use in:
    Konica Minolta Bizhub C250i/C300i/C360i/C450i/C550i/C650i-series
    Maybe also C750i is same toner.
    And you can reset toner in service mode. If you try other colors.
    • Drivee
      • Nov 2020
      • 322
      I would avoid Katun. They are just trade company. better and cheaper to go direct.
      • suomi
        • Oct 2008
        • 152
        The options are few. C458 black color out of stock everywhere
        • splblazer91
          • Jul 2014
          • 204
          tn-712(754e) can be dumped into tn812(808) bottles. Take off end cap and there is a plug. just need a funnel.
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            OK, we still have several REALLY OLD machines in the field that the customers just won't replace. We can't get TN211 or TN311 (for bizhub 200, 250, 222 & 282 or bizhub 350 & 362 respectively) toner any more from Konica Minolta.
            Does anyone know for sure if they changed the toner from the 2 series (222, 282, 362) to the 3 series (223, 283, 363, 423) which is TN217 or TN414? Or will 3 series work in 2 series?
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • Synthohol
              Certified Konica Expert
              • 5735
              Results for BIZHUB
              Aftermarket toner is dirt in a bottle, I'd sooner become a bartender than use non oem supplies.
              • srvctec
                • Oct 2009
                • 827
                Originally posted by Synthohol
                Results for BIZHUB
                We're the same way which is exactly why we're trying to find out what OEM toners are the same over the years. We've got quite a few customers that have really old machines that still work fine but just need some toner. They don't run enough to justify buying a new machine so just want to keep the old one going. For us, it's not a bad thing because they are all on contract and the click price is quite high because that gets raised nearly every year since their lease was up and they bought it out.
                • tulintron
                  • Jul 2014
                  • 669
                  The vast majority of new printers, toner works on older ones. Old in new, no. Black in color, no. Colors in black, yes.
                  • tulintron
                    • Jul 2014
                    • 669
                    Crazy secret.
                    We've had 1250 with C8000 developer and toner in the field, no problem, for over a year
                    • sanvicente
                      • Aug 2011
                      • 31
                      • trscolin
                        • Aug 2012
                        • 21
                        Anyone have any genius ways to transfer toner from bottle to bottle? I look like a smurf trying to transfer some cyan toner using a funnel.
                        • emujo2
                          • Mar 2017
                          • 1580
                          TN 014 to /017--Remove end caps tape bottles together and come back in 1/2 hour (think hourglass) Office swap caps (4 clips that secure the caps) TN 014-Tn016 remove top cap from TN 16, get a funnel, and a vacuum. You can get about 2/3 of a TN -14 into a TN -016. Have not had to swap any production color yet. E
                          • Toxic
                            • 694
                            What replacement oem toner will work best for TN221 toners?
                            I think somebody here claims he use same toner for 4,7,8 series ...
                            • tsbservice
                              Field tech
                              • 7910
                              I think the same. The real question is what toner from bigger models maybe even production(lower price per grams) will work on 4,7,8 series
