Konica Minolta C454 after change MFP board error C-D291
  • tsbservice
    Field tech
    • 8026
    #16
    I'm a bit confused but can you update firmware?
    If machine boot to firmware update screen you can try first only scanner firmware and see what will happen.
    • gateway.vly@gmail.com
      • Dec 2007
      • 52
      #17
      Unfortunately, the machine not allowed firmware updates.always shown invalid external memory error .See the screenshot in post#1
      • tsbservice
        Field tech
        • 8026
        #18
        Try to do trouble reset but instead touching OK enter s00s01 and 9272x4. If you can enter service mode try system error clear. You also can format HDD. Then attempt firmware again.
          • Dec 2007
          • 52
          #19
          We did that not solved the issues.
