Konica Minolta C454 after change MFP board error C-D291
  • gateway.vly@gmail.com
    • Dec 2007
    • 52
    Dears we change the C454 MFP due to the old MFP network port not working the network status led always on even the network cable disconnected . we purchased new MFP board that board always shows error C-D291 , we try to update the firmware then we get error message (invalid external memory).
    the firmware usp work very well with old MFP board.
    any suggestion please.
  • Slammers
    • Feb 2019
    • 136
    Ohhhhh no.
    I had to do this once, and only once for a device that got hit by a lighting strike!!! Exactly the same issue, ethernet port dead, copier fucntional.
    If you have not followed the procedure detailed in the Service manual as well as the additional Technical Bulletin you may have turned your machine into a paperweight.
    There were detailed instructions on how to do this, including a special pre-boot firmware that had to be used in conjunction with the MFP Reset Tool.
    This invloved booting the machine back to KM factory, which causes the display language to revert back to Japanese and other wonderful steps to follow.
    If you have just physically baord swapped the machine and turned it on I am so sorry for you and the pain you are going to have to go through to ressurect your device.
    Good luck.
      • Dec 2007
      • 52
      Originally posted by Slammers
      Ohhhhh no.
      Good luck.
      Thanks for your reply, i have both new and old MFP with me. can you guide me how to do the factory default reset (pre-boot firmware that had to be used in conjunction with the MFP Reset Tool.)
      • copyman
        Owner / Technician
        • Sep 2005
        • 4724
        Make a small donation to this website and PM me your email. I will send firmware to cleanse the MFP board and instructions.
          • Dec 2007
          • 52
          Donation send
          • copyman
            Owner / Technician
            • Sep 2005
            • 4724
            Where did you donate? Sorry I don't see "Site Contributor" under your name.
              • Dec 2007
              • 52
              check PM
              • copyman
                Owner / Technician
                • Sep 2005
                • 4724
                Ok, I sent it even though I don't see site contributer under your name. What you sent me shows you made donation then canceled. I will not send anything else until I see "site contributor" under your name. DON'T ASK! Best of luck
                  • Dec 2007
                  • 52
                  Dear , i made two payment via paypal ,5$ for vip access ,10$ for site support. both payment success.
                    • Dec 2007
                    • 52
                    see
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4724
                      Thanks for donating. Maybe someone else get help or contact admin on why it's not showing under your name. It would benefit you to have "site contributer".
                      • Walterj
                        KONICA MINOLTA
                        • Jun 2017
                        • 89
                        CD291
                        KB0024078
                        CD291 at power ON
                        "CAUSE: New style CCD (p/n A2X0R72111) was installed without updating firmware to G20-K9. Also make sure there is a good connection to the CCD.
                        "SOLUTION: Update firmware to G20-K9 and check the CCD cable (p/n A2X0N14500) connection to the CCD
                          • Dec 2007
                          • 52
                          Originally posted by Walterj
                          CD291
                          KB0024078
                          CD291 at power ON
                          thanks for your reply, the ssd board worked with ols mfp board with old firmware FW_A1610Y0-F000-GR7-M0. old mfc board network port issues.we tried the reset tool copyman send to us . but once the ssd recover done the D291 again shows . can you help me to get G20-K9 firmware
                          • femaster
                            • May 2011
                            • 1514
                            K9 firmware is so old that it is no longer available through the KM USA website. Anything newer should also contain the necessary files needed to work with the newer CCD. If you still have a copy of the GR7-M0 firmware, that is the newest available.
                            Was the MFP board you installed new? If not, you will need to make sure that the machine type set in the board matches the model of the machine you installed it into. Unfortunately, you need the ability to boot into the firmware update screen in order to do this.
                            If it was a used pull, and came from a different model of machine, give this a try. Just note that I have NEVER TRIED THIS, so it may not even work. Try booting the firmware for the model of machine that board came out of, instead of the machine it is in now. If it does boot to the firmware update screen, DO NOT LET THE UPDATE RUN! Use that to change the machine type, then boot again with the correct firmware and hopefully it will go this time around.
                              • Dec 2007
                              • 52
                              Dear Thanks for your support. the mfc board not new .the supplier told its from KM C454 machine. the issue is we use the old ssd bord from our machine . is there any firmware for ssd board update or reset .our old MFC board and SSD board work without any error code .only issue the network port , when we try to firmware update with GR7-M0 firmware ( invalid external memory error shows) and normal boot ( error C-D291)
