Bizhub 4052 c5501 error code
  • blinxwap
    • Jun 2020
    • 80
    Hi guys i have a b4052 that keeps giving c5501 error code at regular intervals the mc is on FIRMWARE VERSION :
    AAP0Y0-F000-G00-X4 the manual suggest its the powersupply after doing system error clear and trouble resetting initializing the mc works for a week or so but than the code comes back any suggestions should i replace the powersupply or fusing unit it also gives fusing code C3421 but rarely not as much as the 5501 in the history 5501 shows almost daily
    Sent from my SM-A725F using Tapatalk
  • tsbservice
    Field tech
    • 8052
    Re: Bizhub 4052 c5501 error code
    I had to replace fuser once for C-3421 code however didn't recall C-5501 to accompany it.
    Edit:
    Better post in KonicaMinolta forum than in General You may see more replies.
    • Woxner
      • Jul 2011
      • 853
      had to replace a power supply for this. i was getting fuser codes. replaced the fuser then a week later the c5501
