Konica Minolta C454e IC CARD Reader Driver
  • SKchadburn
    • Aug 2021
    • 3
    Hi can anyone help me i have the C454e but the HDD went Kaput, I have now replaced the HDD ,updated the Firmware and reinstalled the video file but the IC card does not work any more, i did read that it may need a driver?
    Kind Regards
    Simon
    • 23010
    Re: Konica Minolta C454e IC CARD Reader Driver
    What kind of card reader is it? Yes, it matters. =^..^=
    • SKchadburn
      • Aug 2021
      • 3
      thanks for answering im unsure as its inside the front panel but when i removed the front panel it was just double sided taped to the door but i could find no part number on it it just plugs into the USB port next to the Ethernet port though i can try and disassemble the plate if you require it ?
      Thanks Simon
      • tsbservice
        Field tech
        • 8053
        Originally posted by SKchadburn
        [ATTACH=CONFIG]50222[/ATTACH][ATTACH=CONFIG]50223[/ATTACH]
        Thanks Simon
        Check in service mode under Firmware version to see if any Loadable driver is installed and which one if listed.
          • 23010
          He had to change the hard drive, hence no Loadable Device Driver, and no proof of what driver it used. =^..^=
          • rrrohan
            • Sep 2011
            • 1977
            looks like HID
            unclip it out of the mount so u can read stickers
            • avecosat
              • Jun 2012
              • 305
              You need A5C10Y0-A521_G00-01_Y-Soft
