Konica Minolta Bizhub Pro C-1060L Black Color problem (white dots)
  • matsan_offset@yahoo.com
    • Sep 2016
    • 43
    Hello Masters
    I am having a problem with my machine, black and white dots appear and sometimes I get the error code c-2814, what do you think could be the cause of this problem?
    Thank you for your help.
  • Synthohol
    Certified Konica Expert
    • 5849
    id try:
    swap drums
    swap DV units (cover the holes with tape and leave the toner door open so it wont try top add and see if dots follow the DV unit.)
    if not it should be something in transfer/charging or that carriage position?
      • Sep 2016
      • 43
      Originally posted by Synthohol
      id try:
      swap drums
      Thanks for your help, I will try it and share the results.
