Problem with secure print
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Hello colleagues, in the Cxx4 (IT4) series, when we do secure printing, and print several documents, when we go to the machine and log in, they appear in the order in which they were sent, first 1, then 2 etc, so if we press the “select all” key and print, it does it correctly.
    But in the Cxx8 series (IT5), the documents appear in reverse order, so if we click on “select all” and print, we get the last one first, then the second to last ... and so on until it finally prints the first one we sent.
    I don't see any option to make it do it correctly, as in the IT4 series.
    Does anyone know anything about this?
    Thanks!
    Field technician since 1994
  • Synthohol
    Certified Konica Expert
    • 5824
    reorder.jpghope this helps
    • tsbservice
      Field tech
      • 8013
      Isn't that user box?
      • Synthohol
        • 5824
        secure box is a user box more or less, should have the same options if i recall, been a while.
        • elmaligno
          • Oct 2009
          • 302
          Unfortunately, this option does not appear in the secure print folder.
          • Synthohol
            • 5824
            i really miss having access to machines.
            sorry. was really hoping.
            • elmaligno
              • Oct 2009
              • 302
              I found it! SW119 in 04
