Pale Magenta after replacing drum unit
  • Amrss
    • 46
    #16
    Re: Pale Magenta after replacing drum unit
    ok so if you swapped the cyan & magenta drums round the cyan is good but the magenta still faint then you must have an issue with the magenta developer unit.
    The technician came today and checked it and said that the magenta developer unit had lost some developer, he'll try to add up some developer later today, will update once he does that.
    • Amrss
      • 46
      #17
      So eventually the problem was fixed by adding developer to the magenta developer unit.
      I tried printing a magenta test page and the color was rich
      • tsbservice
        Field tech
        • 8082
        #18
        Yes, one color background almost always bad developer unit/bias or dev/toner mix. Can be drum issue also but background won't be evenly laid on entire page.
        • Amrss
          • 46
          #19
          Thank you sir, and to everyone who replied
