Pale Magenta after replacing drum unit
  • Amrss
    • 46
    Hello,
    After replacing the magenta drum unit, I'm now getting pale colors when printing the magenta test page. Is there any calibration which needs to be done?
  • copier tech
    • 8235
    Re: Pale Magenta after replacing drum unit
    Originally posted by Amrss
    Hello,
    [ATTACH=CONFIG]50315[/ATTACH]
    [ATTACH=CONFIG]50316[/ATTACH]
    What model was this? & was the drum a genuine Konica Minolta?
    • Amrss
      • 46
      No it's not genuine, it's from CET
      The machine is bizhub C554e
      • Albonline
        • Sep 2008
        • 1154
        I think you may have answered your own question.
        • copier tech
          • 8235
          Exactly!
          You can quickly confirm this, swap the cyan & magenta units around see if you get faint cyan & good magenta quality.
          • Amrss
            • 46
            Exactly!
            I went out and tried what you suggested and the results are still the same, is there any calibration which needs to be done after installing a new drum unit?
            • tmmdmmm
              • Apr 2021
              • 173
              No Calibrations for a 4 series, it does it on its own if it detects a new drum. Was the Cyan also an offbrand? This looks like a drum issue, not light developer, not dirty PH, and if its only M its nothing else
              • Amrss
                • 46
                The Cyan drum is genuine, and when printing a test page the Cyan comes out perfect.
                As you stated, the Magenta is the only color that's causing problems. when printing any normal paper the whole page is covered with light Magenta and the red/pink parts of the page appear pale.
                • tsbservice
                  Field tech
                  • 8076
                  Then inspect your magenta developer unit. What is total counter and other consumable counters?
                  • copier tech
                    • 8235
                    • Amrss
                      • 46
                      The whole toner kit is genuine, this is the first time I replace a part in the machine
                      • copier tech
                        • 8235
                        OK, so, for what reason did you replace only the magenta drum?
                        • Amrss
                          • 46
                          • Amrss
                            • 46
                            The bottom part of the page was getting sprayed with magenta
                            the technician I work with figured that the magenta drum is the cause of the problem, after replacing the drum I started facing the problem I posted about. any red/pink color would come out as pale and the whole page would be covered with light magenta lines. I don't know if it's clear in the picture here
                            • copier tech
                              • 8235
                              [ATTACH=CONFIG]50319[/ATTACH]
                              [ATTACH=CONFIG]50320[/ATTACH]
                              ok so if you swapped the cyan & magenta drums round the cyan is good but the magenta still faint then you must have an issue with the magenta developer unit.
