How to easy unlock machine controlled by external App-SafeQ, Papercut, machine itself
  • tsbservice
    Field tech
    • 8082
    [Misc] How to easy unlock machine controlled by external App-SafeQ, Papercut, machine itself
    There are several ways however this is mostly for techs not familiar with KonMin.
    Open Web Connection, Admin mode(default admin password 1234567812345678).
    User Auth\Account Track->Authentication Type->User Authentication - OFF
    One can input same setting using machine touch panel.
  • copier tech
    • 8237
    Re: How to easy unlock machine controlled by external App-SafeQ, Papercut, machine it
    I usually simply turn on public user access.
    • tsbservice
      Field tech
      • 8082
      Thanks for sharing. Can you explain a bit? What's the user experience? Do they need some extra steps involved to use the machine?
      • emujo2
        • Mar 2017
        • 1579
        As you are a usual wellspring of advice, I am forced to wonder why you posted this bit of info...A tech that walks into an account and turns off the 3rd party authentication app is setting him/herself up for a ass chewing..Are you referring to a machine that has come out of the field with the app installed? Simply turning off authentication will not prevent the app from attempting to re install itself. For a machine that has come out of the field with a no longer needed app installed the more correct way would be to remove it via the open API choices in admin mode. E
        • tsbservice
          Field tech
          • 8082
          I know and mentioned that there are other and more proper ways. But every now and then somebody posts here questions like - Hey we buy this machine from seller and it won't unlock. Some techs don't have KM experience and that may help someone in a hurry. Of course removing authentication from machine in the field make no sense.
          Btw thank you for asking because I started to feel like my post wasn't clear enough from ambiguity
