remote diagnostic software
  • Madnhain
    • Dec 2012
    • 148
    I've recently inherited the territory of a tech who has been here for 20 some years. It is a fairly large hospital with a lot of devices. I have no clue how many exactly, though I would estimate in the 6-700 range. All are Konica Minolta 3-4-8 series, and a bunch of HP desktop printers.
    I discovered pretty quickly that the previous tech(s) had gotten lazy and just started disabling trays instead of fixing them, (Product unit isolation). I've stumbled on several in just a few days of being here on site. quite a few band-aid fixes... I'm going to have my work cut out for me.
    I'm looking for a solution to be proactive in my attack, the Hospital Network is pretty well locked down, however I do have a workstation that I could potentially install a server on for this purpose with the blessing of their Technology dept.
    I'm aware of the existence of vCare, though have no experience with implementing it. From what I've heard it doesn't have a dashboard to alert me about issues.
    I have experience with ARMS and MICAS (Ricoh, Sharp) and Kyocera Device Manager... Is there a 3rd party software that scans the network for devices, adds them and reports issues?
    I understand that I may need to add devices one by one to any such service, and although that would be annoying, it could be done over time.
    Anyone have experience with a remote diagnostic software in a healthcare environment?
    Thanks!
    • 30477
    Re: remote diagnostic software
    Kyocera KM Netviewer will find all network devices
    Also print tracker
    • Samanator
      • Sep 2017
      • 579
      With Kyocera KM Net Viewer, you can right click on any non-Kyocera device and there is an option to go to that devices home page. There is other information for each device as well.
      Might be helpful. I have had a couple of IT guys use KMV to monitor devices over their network. Lets then know if the device is running low on toner or if something is wrong the line goes red or a yellow caution tangle pops up.
      Basic info at a glance.
      Hope that helps.
      • tsbservice
        Field tech
        • 8052
        Hope that helps.
        I think he wants more automated tool. We have Brother tool BRAdmin 4 which does the same as KMV but the problem is those are vendor limited to core part of their functions and Konica Minolta doesn't seem to have good enough tool.
        • emujo2
          • Mar 2017
          • 1579
          KM's page scope enterprise suite can alert you of a ton of KM isssues..Free from KM, can be run on a desktop. it's been a while, but you can add other vendors, but you need the SNMP OID for anything other than KM. you can make some changes fleet wide..It's a lot of work to get everything reporting, but once it's done you just sit back and wait for the emails. E
          • Madnhain
            • Dec 2012
            • 148
            Sounds like KM PageScope Enterprise might be the way to go...
            I failed to mention a key point, the hospital network is LOCKED DOWN tight with no out-bound traffic allowed. Any application would need to be located locally on the network and not rely on reporting to a cloud-based or exterior server.
