c250i gradation doesn't work
  • Stefan H
    • Nov 2024
    • 40
    Hello everybody
    I currently have a problem with a c250i. This had a magenta stripe on the prints. So I replaced the drum. Before I did a gradation, I made a test print to see if the problem was resolved. However, this one had a strong magenta background.
    The first thing I did in the service menu was stabilization. After that I selected A3 and the printer 600dpi. Unfortunately I have the problem that the start button is not active. That tells me so much that the stabilization didn't work.
    When I removed the developer unit, I noticed that the entire starter had now been pulled out. I will have to swap the developer unit. However, there is a problem that the gradation cannot be carried out. Unfortunately I can't get a solution. Do you have an idea how to fix it?
  • Synthohol
    Certified Konica Expert
    • 5842
    replace drum and dv UNIT at the same time?
    whats with the weird icon attachments?
