Problema c258
  • hechizero
    • Nov 2024
    • 3
    Problema c258
    Hello, I have a problem with c258, I don't know where to change the type of paper that is in each tray, I have put normal paper in 1 and Thick 3 in 2, I have looked in all the menus and through web access as an administrator, but I don't see it, and I need to pass tray 1 to Thick 2
  • hechizero
    • Nov 2024
    • 3
    The problem is that I have to print on the two trays with papers thicker than 200gm, and since normal paper is put on the two trays it prints me by dragging the toner.
      • 23009
      It's in the users manual, right here:
      Utility > User Settings > System Settings > Paper Tray Settings > ...
      • tsbservice
        Field tech
        • 8020
        Boy... should we have more customers like you for Christmas wish 😜
        Yes please 🙏
        • hechizero
          • Nov 2024
          • 3
          I'm looking for it in settings and there I only found it for the car tray, from what I see I have to go to copy to look at that adjustment, I would never have thought of it 😂😂😂😂
