Compatible Toner TN619,TN620
  • ramilabels
    • Oct 2021
    • 2
    Hi with this toner shortage issue that happend because of some "fire"
    I know TN619,TN620 are the same. What else is their that will work with it?
    Anyone try anything OEM?
  • lartis.aineias
    • 78
    Re: Compatible Toner TN619,TN620
    Yes is the same toner
    C1060,2060,3070 they have the same developer and the same toner!
    Only the bottle is different.
    with the right modification you can use them!
    [emoji6]
    Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
    • heavyd14
      • Sep 2008
      • 10
      Did it work? I'm running into the same issues with toner shortages. I have a customer that has a c1060 and the toner is next to impossible to get here in the States. They have a TN620 that they ordered off of Ebay that is OEM, but it will not fit. They asked me how to swap it and I don't do that. I've always just ordered new and moved on. What is the process for opening them up without creating a huge mess? Is this something that I should take back to my office to complete or something I do in their office without making a huge ordeal.
      Thank you,
      Dustin
      • orestesp
        • Sep 2019
        • 230
        Thank you,
        Dustin
        The cap on the bottom of those toner bottles is rather easy to remove without a lot of prying and also to reinstall. You can open both up and then use a funnel to transfer the toner from the old to the new. Probably the cleanest way there is.
        Done that once or twice.
          • 16462
          Thank you,
          Dustin
          Under no circumstance do you refill a toner cart. in a customers office. That's crazy talk.
