Konica C4050i firmware trouble
  • AlexanderYan
    • Nov 2024
    • 6
    Hello, I have Konica with the problem. When machine starting, after 30 sec on display message *This is invalid External memory*. I have firmware but machine not take them, and write firmware error(( Please help me. Give please solution, new firmware or somethig else.my adress sundarmail@mail.com
  • ronny2502
    • Mar 2020
    • 79
    Hello,
    very likely "Memory Board / Storage Board" - AA2JM72Q00.
    Regards,
    Ro
    • AlexanderYan
      • Nov 2024
      • 6
      Originally posted by ronny2502
      Hello,
      Regards,
      Ro
      Maybe i need new firmware or reset file ( Please help me, if anybody have firmware or reset file (tar) send me on my email. Please(
      • ronny2502
        • Mar 2020
        • 79
        Hello,
        Sent you a PM with a link (latest FW G00-RF).
        But be aware that the memory (memory Board / Storage Board) may be faulty.
        Regards,
        Ro
        • AlexanderYan
          • Nov 2024
          • 6
          Hello,
          Regards,
          Ro
          Thanks a lot for firmware. But it not help( Firmware error
          If i change new SSD may i take any brand memory or i need only AA2JM72Q00.?
          • tsbservice
            Field tech
            • 8008
            It doesn't hurt/cost to much to try another SD card.
            • AlexanderYan
              • Nov 2024
              • 6
              i try 4-8-16-32gb kingston not working(
              • Duplicator
                • May 2022
                • 245
                That white screen with "Firmware Error Occurred" that looks like the screen from the firmware updater when it fails the integrity check. Are you sure your copy of the new firmware is good?
                Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
                If I helped you out, please give me a thumbs up! It helps my reputation.
                • D Colour
                  • Oct 2008
                  • 213
                  Im assuming the machine boots up to ready, if you are not trying to update the FW?
                  Check these steps from the manual.
                  System preparation
                  • PC with USB ports
                  • USB memory
                  • USB flash memory compatible with the USB (1.1/2.0/3.0) interface. The speed is limited to USB2.0 specifications even if using a device that supports USB3.0.
                  • The USB memory is formatted in FAT32 format.
                  • No security functions such as encryption and password lock have been added (or the USB memory allows its security functions to be turned OFF).
                  • A USB memory that is recognized by the computer as two or more drives cannot be used.
                  Everything that has a beginning, has an end.....
                  • AlexanderYan
                    • Nov 2024
                    • 6
                    Hi, I have 2 version firmware and all of them not working. I think its CPU-B or SSD . I dont know, can i format SSD memory or not, for understand SSD or CPU-B is bad.
                    • AlexanderYan
                      • Nov 2024
                      • 6
                      System preparation
                      • PC with USB ports
                      • USB memory
                      i check all this point, and not helped!
                      • Duplicator
                        • May 2022
                        • 245
                        We have had that issue when we have used bad flash drives or bad copies of the firmware image. You will be unable to even get to the point where you could format the SD card or SSD inside the copier since it's not fully starting the firmware updater.
                        You should receive a different error for bad CPU-B or bad SSD/SD card. Are you able to boot the Diagnosis and Recovery tool?
