Re: Konica Minolta C554e + C658 Driver
Is the papercut reader a CCID, or keyboard wedge, or both? I don't think you can use the LDD tool for CCID. I would grab the C658 KBW driver and use the tool to build it with the Papercut VID/PID. No idea if this will work. E
EDIT ' think ive found itLeave a comment:
only 85$ for the compatible reader...
Amazon.com: RF IDeas PCPROX Plus 82 Series USB Reader RDR-80582AKU : ElectronicsLeave a comment:
If you can get the hardware IDs you might be able to create one with the LDD tool, but there are no built drivers for this type of card reader..ELeave a comment:
Hi guys,
does anyone have to correct driver for a TWN4 MultiTech paper cut card reader.
will need it for a C554e and C658 machine.
i have tried to use multiple drivers from Dbox but none have worked so far,
currently getting 'unable to connect to authentication device' error,
have upgraded C554e to GDL-M1 firmware and is on function version 7
