C258 error code C-C164
  • tulintron
    • Jul 2014
    • 668
    C258 printing USB port, FW G00-W4
    Electric discharge caused D011.
    After repairing the MFPB board, D011 continued.
    I got MFPB from a working C368.
    Removed EMMC, 02 Eeprom's, HDD.
    Installed EMMC, 02 Eeprom's, C258 HDD
    Install FW G00-W4 and after power on, C-C164
    part number of identical MFPBs. (A7PUH020)
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: C258 error code C-C164
    Hi,
    MFP board procedure gone wrong you need to enter the machine type info before at the beginning of FW also ensure that the original EMMC of the machine is mounted on the board.
    Your best bet is to have the board reset and go through the board replacement procedure as per SM.
    • tulintron
      • Jul 2014
      • 668
      Originally posted by byronf
      Hi,
      [ATTACH=CONFIG]50497[/ATTACH]
      Machine type successfully entered and exchange procedure agreed with SM.
      I've read in other posts that boot firmware is required. I have several base FW. Do these base FWs have the boot file included?
      My FW Base starts at G00-16.
      • tulintron
        • Jul 2014
        • 668
        Some help?
        • Synthohol
          Certified Konica Expert
          • 5822
          D011 i thought was a HDD issue?
          Related Products:bizhub C368,bizhub C258,bizhub C308,MFX-C2590,MFX-C3090,MFX-C3690
          Related Options:
          Error
          CD010, CD011, CD050, CFA14 and/or miscellaneous HDD errors.
          Root Cause
          Corrupt data.
          Workaround/Fix
          Install Recovery Tool firmware GXX-A8 or Preventive firmware GXX-B0.
          • tulintron
            • Jul 2014
            • 668
            Thanks, Synth.
            I performed this procedure as well, according to the bulletin, but did not complete the procedure.
            I changed HDD, updated FW, performed bulletin step D011, but without success.
            We decided to exchange MFPB. Then I come across C164.
            • tulintron
              • Jul 2014
              • 668
              Related Options:
              Error
              Root Cause
              Corrupt data.
              Workaround/Fix
              In this procedure, Sata Controller FW has an error and does not update
              • tsbservice
                Field tech
                • 8008
                Try it without and later update it
