Konica Minolta C368 Scan to SMB
  • JVC
    • Jun 2011
    • 151
    Hello,
    I am refurbing a number of Bizhub C368. After delivering a couple and trying to networking them I have found that when I try to add scan to file smb there is no place to enter the User ID or Password. On most of the machines the User ID and Password are there and I can set up the scanning. This lot came in with the hard drives removed and a number of settings changed. I am hoping I am just missing something in the admin or tech rep settings. Any help is greatly appreciated.
    Thank you
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: Konica Minolta C368 Scan to SMB
    Yes, a HDD is required for smb scanning.
    • JVC
      • Jun 2011
      • 151
      Thank you for the reply. I reread my post and I forgot to mention that I installed new hard drives formatted them and everything seems to be working correctly. The issue is when using the web interface to enter an address and select smb scanning there is a not a box to enter the user name and password. The box for Host and file path is there. Any idea of where I need to tell the machine to turn on these boxes?
      • tsbservice
        Field tech
        • 8053
        How did you format them?
        • JVC
          • Jun 2011
          • 151
          In service mode I performed first the physical and then the logical formatting. Then I loaded the animation guide.
          I just started working on an additional machine. When I went into store addresses and selected smb there were the 4 places Host Name, Path, User Name and Password. I installed a hard drive formatted it and then had to do a memory clear. After doing the memory clear the user name and password boxes disappeared. Doing the reset I must have turned something off. Any idea what I need to turn back on?
          Again Thank You in advance for any help.
          • Synthohol
            • 5892
            i would try firmware then.
            • romario
              • Jun 2020
              • 193
              Hello,
              Thank you
              I got a batch of copiers the same, without hdd, and that option did not appear, I started the factory options install hdd, format hdd and ready I could scan to smb
              thanks
              • mojorolla
                The Wolf
                • 2633
                Service mode > System 2 > HDD, make sure it is set to installed.
                Format, firmware and animation guide
