Bizhub c454e bypass tray problem
  • Mikhail_85
    • Dec 2024
    • 2
    Hello! One day there was a problem with the bypass tray, when trying to print on it, the device reports that the tray is not installed. I need to print on paper with a density of 300 grams, and this is only from it.
    • 23009
    Have you done a System Error Clear? Most likely there is an error stored that has disabled the bypass tray. Print off the Management List to see what the error was.
    • aberock
      • May 2022
      • 124
      try check in System 1 > Unit Isolation .
      • Mikhail_85
        • Dec 2024
        • 2
        Thank you so much! It is not known how the setting went wrong there. Nobody approached the device.
