3070L & PF 707M
  • Maury
    • 2
    [Misc] 3070L & PF 707M
    Buongioro a tutti un ho Cliente Che ha Una 2070 con PF 707m ha acquistato Una 3070L Nuova ma non riesce ad utilizzare o meglio a far riconoscere alla 3070L PF 707m
    Ho gia del fatto il confronto dei Dip Switch 2070 con PF 707m installato una 2060L ma non ho trovato nulla di diverso e visto che i firmware sono gli stessi non so come risolvere il problema
    qualcuno ha qualche IDEE oppure ha mai provato un FARLO ???
    grazie mille
  • lartis.aineias
    • 78
    Re: 3070L & PF 707M
    grazie mille
    La serie L supporta solo lu202xl lu202m e finisher fs531 + fs612
    Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
    • Maury
      • 2
      Re: 3070L & PF 707M
      [CITAZIONE = lartis.aineias; 1952697] La serie L Supporta solista lu202xl lu202m e di finitura fs531 +
      fs612 από το AC2003 μου χρησιμοποιώντας Tapatalk [/ quote]
      Grazie mille Sono un Tecnico e this lo sapevo, vorrei trovare Una Soluzione x this Cliente Che HA UN Accessorio Che costa OLTRE 6000 euro e non riesce ad utilizzarlo
      grazie Mille
      • lartis.aineias
        • 78
        Re: 3070L & PF 707M
        grazie Mille
          • 23010
          Re: 3070L & PF 707M
          translated to English:
          Maury:
          Hello everyone, a customer who has a 2070 with PF 707m has bought a new 3070L but is unable to use or better recognize the 3070L PF 707m
          I have already compared the Dip Switch 2070 with PF 707m installed a 2060L but I have not found anything different and since the firmware are the same I do not know how to solve the problem
          does anyone have any IDEAS or have they ever tried a DO IT ???
          thanks a lot
          lartis.aineias:
          L series only supports lu202xl lu202m and finisher fs531 + fs612
          Maury:
          Thank you very much I am a technician and I knew this, I would like to find a solution for this customer who has an accessory that costs over 6000 euros and cannot use it
          thanks
          lartis.aineias:
          Unfortunately, as far as I know, this possibility does not exist!
          That's why the 3070l is cheaper than the 3070pro
          if the translation is not correct it is because I made it from Google translate. [emoji41]
          blackcat4866:
          Yes, as far as I know, the PF707m will not communicate with the "L" series.
