konica minolta c301i marketplace and default operation mode question
  • brent
    • Nov 2008
    • 1208
    ok on markeplace I have usually went into admin and changed basic to classic style to get back to normal screen this time the default operation mode setting is not even there second from the bottom any thoughts? also in iws marketplace to off. I switched it plus soft switch 172 from 5 to 01 then fix.. it still goes into marketplace. this is a new series and have not seen these issues before.. I will keep on looking thanks all
    brent
  • brent
    • Nov 2008
    • 1208
    upon further looking I do believe marketplace is fixed. just not sure about the classic mode I cant see how people don't like or use the original classic screen like fom the 90s like me
    lol thanks
    • brent
      • Nov 2008
      • 1208
      well I guess I found it.. its in the same menu twards the top. sorry for the post if I could erase it I would lol
      brent
      • Synthohol
        Certified Konica Expert
        • 5735
        its all good, ive had self starting and closing threads as well
        • tsbservice
          Field tech
          • 7908
          They moved some things around. Basically nothing dramatic. You can always use search field in admin mode to find a link to settings. It depends on firmware and functional version. 2.3 is what you seeing. You will get used to that shortly.
