Registering New Theme 4 & 8 Series
  • CopierNerd
    • Feb 2015
    • 207
    Hi,
    I want to change the panel display theme of Konica 4 & 8 series. In 4 series the register option is not showing. I am not sure it's because of the firmware or 4 series does not support changing of theme.
    In 8 series I can see the register option showing.
    * Admin Mode > System Settings > Display Settings > Main Menu display Settings > Theme Register
    Default 3 themes are showing. When I tap on "Register" to add new theme. It gives error "Cannot find registered File"
    USB is connected and working. File Type is PNG. Resolution is 1024 x 768. 32 bit. Size 1.5 mb. File name : Registered.PNG
    Why it is giving error when the file is already there and matching the requirements?
  • tsbservice
    Field tech
    • 7970
    Originally posted by CopierNerd
    Hi,
    • CopierNerd
      • Feb 2015
      • 207
      Its working now. Thanks!
