AU-201h LDD Not Working for Omnikey 5325 CL (no card slot) on Bizhub 224e-554e
  • captainrva
    • Oct 2014
    • 100
    I have an Omnikey 5325 CL and a 5325 but the AU-201H driver only works for the regular 5325, not the 5325 CL with the Bizhub 224e-554e MFP's. Is there a tool to configure these to be the same or a way to browse to the readers config file? I tried the Omnikey Workbench 2.2 & 1.8.1 but it just says there is no CCID driver installed even though I installed the latest driver and it never finds the readers.
    Any help is appreciated.
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: AU-201h LDD Not Working for Omnikey 5325 CL (no card slot) on Bizhub 224e-554e
    Did you select "card" in vendor mode?
    Also I think pcprox app may help
    • emujo2
      • Mar 2017
      • 1579
      plug the 201H and the 201HCL into your laptop and find out what the hardware IDs are..the LDD for the Au201H (not the CL) only supports one type of ID..
      • captainrva
        • Oct 2014
        • 100
        Hardware ID's:
        5325 CL: USB\VID_076B&PID_5124&REV_0510 - USB\VID_076B&PID_5124
        5325: USB\VID_076B&PID_5125&REV_0510 - USB\VID_076B&PID_5125
        • captainrva
          • Oct 2014
          • 100
          Yes, card is selected in vendor mode and works fine for the 5325 but if I swap them then I get the "Cannot connect to authentication device" error.
          I tried the pcprox app but it just says no devices for either of them as well.
          • emujo2
            • Mar 2017
            • 1579
            Originally posted by captainrva
            Hardware ID's:
            This is your problem..the old CCID LLDs had the hardware IDs programmed in..Possibly you could open the LDD and edit the VID/PID codes. Km never sold the 5325 CL version.
            There is an LDD tool that lets you add the VID/PID (ie using the Mifare PCProx reader), but I think only KBW mode is supported, and the AU201 is strictly CCID. what about moving to the AU205H??
            • FixitYo
              • Sep 2020
              • 15
              Newer AU205H come in Keyboard Wedge Mode, plug it into your labtop remote into it and put it in CCID mode. If you need specifics let me know, should be straight forward.
              • captainrva
                • Oct 2014
                • 100
                I tried the web interface (192.168.63.99) but I just get page not found error. I have the EEM driver and CCID driver installed.
                The reason I can't use the 205h is we have about 30 of these 201h already installed for the customer and we'd have to change them all to 205h's.
                • emujo2
                  • Mar 2017
                  • 1579
                  There is special drivers written for the AU-205H to make them behave like a AU201H..This was specifically made for Equitrac so you could use both as new machines were added that did not support the older readers. You can find this on the KM site under CCID Mimic..nothing is supported past the 8/8e series and the C759. E
