Brand new Finisher FS539SD, flaking
  • Bman
    • Dec 2023
    • 9
    this unit is on a c451i and works fine until you run a folded job. it will run some then make a weird noise in the finisher and the machine falkes out and reboots or locks up. I have already done firmware and its the latest etc. Only thing I could find was the lift arm form the bottom stacker "feels" like its rubbing or scraping when you manual raise it up and down. any ideas greatly appreciated
  • copier tech
    • 8167
    Is it logging any error codes in CE mode ?
    • tsbservice
      Field tech
      • 8020
      Probably silly question but have you removed all orange tapes inside finisher?
      • Gift
        • Mar 2011
        • 2459
        Yup in case he did I'd probably say it's a "dead on arrival" case. One might check the wiring+connectors as a last attempt.
