TPM chip has been changed. Initialize TPM setting
  • mearmi
    • Oct 2010
    • 350
    [Misc] TPM chip has been changed. Initialize TPM setting
    Hi All
    Konica C454e Got error this morning "TPM chip has been changed. Initialize TPM setting"
    Went through all the threads. Couldn't find the solution.
    Can someone advise any solutions to restore the machine.
    Many Thanks
    mearmi
  • Slammers
    • Feb 2019
    • 136
    Check in the service manual in section "8.102: Security Settings - TPM Setting" and also in section "13: I-Option" specifically the information regarding LK-115.
    Not in the workshop just now to check this fully but it sounds like TPN has been enabled with no LK or something has happened to the mainboard and settings have been lost.
    • Thib
      • May 2017
      • 35
      That is going to be the battery on the MFPB. If you can source them and solder, it's doable.
      • mearmi
        • Oct 2010
        • 350
        Just changing the battery will restore the machine? Kindly advise. Thanks
        • SAR
          • Jul 2009
          • 203
          This procedure has worked for me. It was posted on here previously. battery issue (2).jpg
