Forgotten admin password / factory reset Konica bizhub C3120i
  • maxtemp7520
    • Feb 2025
    • 5
    Hello everyone, I hope someone will have the solution to my problem.
    I have had a Konica C3120i printer since June 2024. No problem with it so far.
    I set it all up from the administrator interface with the "admin" login and I changed the default password which is the serial number.
    Problem: for several weeks, I have been unable to connect to the administrator interface even though I have not changed anything. I always have the message "The username or password is incorrect" and after 5 connection attempts, I have to turn it off and on again each time.
    Admin login and password, it does not want to.
    Admin login and default password (serial number), it does not want to.
    I also tried with my administrator name, email address in login, nothing works.
    When I turned it on, I held down both buttons to enter the "Special Boot Menu", I pressed "Password initialize" and nothing either.
    Does anyone have a solution to reset the administrator password?
    I contacted Konica, the price asked to intervene is more than 50% of the new machine even though it is not 1 year old.
    Thank you for your feedback.
  • tsbservice
    Field tech
    • 7970
    Can you post a picture of this "Special Boot Menu"?
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5795
      cant you go into service mode. stop-9 and change the admin password there like normal?
      • tsbservice
        Field tech
        • 7970
        Well... forget about it just opened manual. It's not usual KM stuff there so no way as we did. We had zero of these in the field.
        • maxtemp7520
          • Feb 2025
          • 5
          Yes, this is the picture of the menu.
          This gallery has 1 photos.
          • ronny2502
            • Mar 2020
            • 78
            Hello,
            this model (bizhub C3120i) doesn`t look like konica minolta. - It could be developed by lexmark. - In that case you'll (could) find a jumper on "mainboard" to reset settings.
            No warranty! But have a look at this: https://www.youtube.com/watch?v=nXs9x-KZWhM
            best regards,
            Ro
            • maxtemp7520
              • Feb 2025
              • 5
              Hello,
              There is no button or jumper on the mainboard.
              Regards.
              • ronny2502
                • Mar 2020
                • 78
                Hello,
                sent you a PM with link to SM.
                Maybe you can reset AdminPassword in ServiceMode.
                Regards,
                Ro
                • maxtemp7520
                  • Feb 2025
                  • 5
                  Hello ronny2502,
                  Thanks for the Service Manual document, I managed to restore the default settings.
                  Problem solved !
                  Regards,
                  Maxime
                  • Patryk Cz
                    • May 2025
                    • 1
                    Hi maxtemp7520,
                    I've the same problems, could you please give me some tips how did you solve it?
                    Configuration Mode still required the password, and Safe Mode didn't help either.
                    • ronny2502
                      • Mar 2020
                      • 78
                      Hello, Patryk Cz
                      sent you a PM a couple of days ago.
                      Did it help to solve the issue?
                      best regards,
                      Ro
                      • maxtemp7520
                        • Feb 2025
                        • 5
                        Hello Patryk Cz,
                        I was indeed able to reset the printer to default mode thanks to the comprehensive instructions sent by ronny2502 .
                        You need to unplug the printer and plug it back in while pressing the "home" button.
                        You will arrive at a SPECIAL BOOT MENU screen.
                        You need to press the words "BOOT" and "MENU" on the screen and press the "home" button while holding down BOOT and MENU.
                        A numeric keypad will appear. Enter the code: 63656#
                        Then OK.
                        Click on the "CE Diag" menu.
                        In this menu, I cleaned everything the menu allowed.
                        In "Installation":
                        Clear All NVM
                        Clear Job History
                        Clear Accounting PV
                        Clear Device Data
                        Then, the last menu at the bottom: "Exit Mode", OK, and the printer will reboot with the default password (serial number).
                        Hopefully this will work for you too.
