Load check to drive exit rollers on mf454/254 (Konica c458/258)
  • pez
    • Jul 2015
    • 19
    Quick question regarding the paper exit of the Olivetti MF454 and MF254 - I need to drive the exit but when running a load check 45/ 1-4 I can hear the m3 motor turning, but I can't see how to energise the CL8 clutch to get the exit roller turning (transport control lists it as being energised when paper enters the fuser and then deenergised when the paper is fed a predetermined distance after exit).
    Is it possible to use Load Check to drive the exit rollers?
    Thanks in advance.
  • Synthohol
    Certified Konica Expert
    • 5814
    21-3 is exit clutch
    21 1 CL2 Tray2 vertical transport clutch Drives the specified clutch. It is only used on
    bizhub C368/C308/
    C258.
    2 CL4 Registration clutch It is only used on
    bizhub C558/C458/
    C368/C308/C258.
    3 CL8 Paper exit clutch Drives the specified clutch. It is only used on
    bizhub C658/C558/
    C458.
    4 CL9 Paper exit deceleration clutch
    you can energize the clutch and feel if the rollers resist turning free?
    dunno if the c258 is the same per note.
