BH-4050, is there a "Paper Passage Test"
  • Hansoon
    • Sep 2007
    • 3391
    Has the BH-4050 a Paper Passage Test similar to the larger machines? I cannot find it. Would like to test the machine without using up the toner or increasing the counters.
    Hans
  • Synthohol
    Certified Konica Expert
    • 5853
    Re: BH-4050, is there a "Paper Passage Test"
    1. Call the Service Mode to the screen.
    2. Touch these keys in this order: [State Confirmation] -> [Paper Passage Test].
    3. Select the paper feed tray to be tested.
    4. Press the Start key to start the paper passage test.
    5. Pressing the Stop key will stop operation.
    sent you a PM too.
    • tsbservice
      Field tech
      • 8028
      Just adding to what Synthohol already cleared. There is paper passage test and for ADF unit - single and two sided.
