C3350 swapping IU's ???
  • 3ktlc
    • Feb 2018
    • 180
    Re: C3350 swapping IU's ???
    Originally posted by copyman
    That's what I heard as well. Agree the small Kon/Min machines are not that great. I will put the bigger Kon/Min up against any other OEM. Only one close would be Canon.
    Of course each Tech has their favorite OEM which is usually the OEM they have most experience with...
    I have worked on Konica's since there were Royal. Back in the days oh the 110/115/130/145's up to today. I also had been trained on Xerox, Mita's before the became Kyocera, & Panasonic. Always thought I would stay with the Km's. These new Ricoh's have been very reliable and the customers love them.
    • boot
      • Jan 2022
      • 3
      can i swap color IU with swapping chip? yellow instead of magenta and vice versa? for testing a charging
      • allan
        RTFM!!
        • 5462
        Replace the ICP on the TCR chip. That will reinitialize it. Its even possible to convert b/w to color.
        If you get a TCR range error best to replace it. Shake the crap out of the replacement to ensure the toner mixes into the dev.
        The CMY TCR chips are not the same as for the b/w unit. Think its only a SMD resistor that makes them different.
        Whatever
        • copyman
          Owner / Technician
          • Sep 2005
          • 4654
          #19
          Comparative lack of Canon techs and threads here works in favour of your words
          Or could be just more Kon/Min machines are sold.
