bizhub c330i - card reader issue
  • Haxon
    • May 2019
    • 4
    Hi all. Was wondering if anybody knew which driver to use for this card reader?
    Printer is a bizhub c300i, i have been on Knova and tried all the loadable drivers i can find there, they either dont load on, or they do load on
    but when i reboot, it says unable to connect with authentication device.
    I have swapped card reader for one i know is definetly working and get same issue, so its not card reader, customer can login to Papercut embedded using user
    name and pass, just not card reader
    Thanks in advance all
  • emujo2
    • Mar 2017
    • 1579
    Re: bizhub c330i - card reader issue
    KM offers drivers for the AU205H and Mifare..you would not use a papercut reader directly on a km device, however, the fast release card readers can be used to authenticate and perform follow me printing at devices that do not have the ability to log in from the large LCD screen. It's possible you might be able to use the LDD tool and create a driver using the papercut hardware IDs. E
    • Haxon
      • May 2019
      • 4
      Thank you for your help. Thats pointed me in the direction i need, many thanks.
      • diedux
        • Jan 2017
        • 124
        You can attach it directly, without a loadable driver, and use it as a "keyboard". One drawback of using this configuration, you lose the card self-association with existing user accounts.
        • B0265
          • Jan 2007
          • 718
          Search for Elatec TWN4 in Knova, I think there are drivers available.
          • usink
            • Feb 2023
            • 7
            [ATTACH=CONFIG]50891[/ATTACH][ATTACH=CONFIG]50890[/ATTACH]
            you used this link ,this driver used for KMc300i/360i Google Drive: Sign-in
