Bizhub 220 c - 0211
  • Elias
    • Dec 2019
    • 12
    Bizhub 220 c - 0211
    Hello
    I have this message c- 0211.
    Thanks for help.
  • copier tech
    • 8220
    Re: Bizhub 220 c - 0211
    Originally posted by Elias
    Hello
    Thanks for help.
    Check the by pass, they often get knocked especially if the copier is by a door etc.
    • Code: C0211
    • Description:Remedy:1 Check the connector between M1-PRCB CN14 for proper connection and correct as necessary. 2 Check the connector of M1 for proper drive coupling and correct as necessary. 3 Check the connector between PS26-relay CN93-PRCB CN19 for proper connection and correct as necessary. 4 Check the connector between SD1-relay CN99-relay CN93-PRCB CN19 for proper connection and correct as necessary. 5 PS26 I/O check, sensor check. 6 SD1 operation check. 7 M1 operation check. 8 Change M1. 9 PRCB ICP5 conduction check. 10 Change PRCB. Update the firmware.
    • Elias
      • Dec 2019
      • 12
      • Code: C0211
      • birchcourt
        • May 2011
        • 20
        Remove sticking seal naerby lifting selenoid
        Verstuurd vanaf mijn SM-A525F met Tapatalk
