BH 1100 Slow Printing
  • splblazer91
    • Jul 2014
    • 204
    They have 2 machines. Only one is messing up. Does it with crossover from my laptop as well. It is slow to print and takes about 30 seconds to pull up the printer preferences. Web Interface is also inaccessible.
    Heres what Ive tried: NVRAM rewrite, FW Update(ver 90), Format Controller HDD and 3 different print drivers.
    Any ideas before I replace Controller Board?
    • 30477
    Re: BH 1100 Slow Printing
    did you try a data clear?
    and reset the nic
    • splblazer91
      • Jul 2014
      • 204
      There arent initialization settings on an 1100 like there are on the office devices. I did the controller hdd format which wipes the network settings though.
        • 30477
        try replacing the hhd
          • 16473
          Before you replace anything, I would check to make sure that you LAN Interface speed is set to AUTO or whatever setting matches your network...which is most likely Gigabit.
          • splblazer91
            • Jul 2014
            • 204
            FIXED!
            Replaced Controller today with no luck. Tech Support was no help so I started searching KB Articles. Found one for the 8 series. It had me go into the driver and turn off auto obtain settings.(Bi-directional communication) This resolved my problem.
            • tsbservice
              Field tech
              • 8053
              FIXED!
              Good find splblazer91! Really shows you the idea behind "better measure twice before cut"
                • 23010
                FIXED!
                Thanks for sharing! =^..^=
