C-00117 PF-707M on a C3080
  • methogod
    • Dec 2008
    • 921
    [Error Code] C-00117 PF-707M on a C3080
    This is an intermittent issue, happens only in the AM, when machine is "COLD" from sleeping.
    after code, if i unplug Clutch CL3 on the PF i can run all day from tray 4 and 5.
    After few hours i can plug CL3 back in a run from tray 3.
    Swapped M2 and M1, no change. Swapped all clutches from Tray3 to Tray 4 - to see if something changed.
    Clean all of the vertical transport bushing, and Horizontal bushings. Even the ones on the doors. Was a little dirty but not bad.
    I can try firmware next, i also have another PF707m i can swap boards or PS.
    I know its most likely a failing clutch, but i cant figure out how to narrow it down...
    Correct SOlution I will buy you dinner, drinks or weed (if legal in your state - otherwise 2 dozen eggs.)
  • wjurls
    • Feb 2017
    • 498
    You need to replace all 6 clutches on the vertical conveyance unit. Not just one or 2. All 6!!
