BH-C-284e, difference between boards inside front panel
  • Hansoon
    • Sep 2007
    • 3391
    I've seen machines with a small board LEDCB and some with a large board LEDCB inside the front panel under the control unit. In the older parts manual (2013) the larger board is listed, in the newer part manual (2016) the small board. Any practical difference I didn't notice yet?
    Hans
    • 23010
    Re: BH-C-284e, difference between boards inside front panel
    There's an old style part: A5C1H00E01
    and a new style part: A161H00U01
    As far as I know you can use either interchangeably. I would assume that the new style part is improved in some way ... but if a new style part has failed, it's failed, and either type that works will be better. =^..^=
