BH-C-284e, not waking up from sleep mode.
  • Hansoon
    • Sep 2007
    • 3394
    Machine does not completely wake up from sleep mode. Display is showing two fins but the machine does not continue booting. Only completely switching off/on release this situation, than it works fine until the next sleep mode. I remember that this was an issue in the past discussed here but could not find with the search mode in the panel the reason for this problem. Any other solution than deactivation of the sleep mode? Tried Latest & Greatest "Frimwar" already.....
    It has now A5C10Y0-F000-G20-M1
    Hans
  • Toxic
    • 698
    Re: BH-C-284e, not waking up from sleep mode.
    Try this settings
    SM-System 1 -> Sleep ON/OFF Choice Setting Permit
    Admin mode
    Low Power Mode Setting 15 min
    Sleep Mode Settings Off
    Power Save Settings Low Power
    Power Key Setting Sub Power Off
    Enter Power Save Mode Normal
    • D Colour
      • Oct 2008
      • 217
      In addition to Toxic's post...
      TIB362Plus_ Machine does not wake up from deep sleep Rev2.pdf
      It advises to turn the weekly timer off and turn off SSDP in network settings.
      Everything that has a beginning, has an end.....
      • copyman
        Owner / Technician
        • Sep 2005
        • 4772
        We turn off sleep mode on all the "4" series. There was a bulletin about machines not waking up from sleep mode. Machine will still go into energy save mode but not fully to sleep.'
        Like other poster wrote you have to go into service mode and "permit" sleep to be turned off in Admin mode.
        • tsbservice
          Field tech
          • 8053
          Just another addon I find it very helpfull especially last reply made by TheOwl.
          Bizhub c284 wont print without restarting machine (reposted from Connectivity forum) [Archive] - Copytechnet.com
          Cheers guys and keep up the good work!
