About Bizhub Pro Filters
  • John Kaufmann
    • Sep 2013
    • 115
    #16
    Two things to watch.
    1. Works on 45+ppm machines.
    Does that mean it does not work with lower-end machines? (The size looks OK for 36- machines.)
    2. Doesn't fit INTO regular/standard toner vacuum hose because of same size you should hold them together firmly to not loose suction or just use some tape.
    That sounds like an invitation to do an SLS (3D-print) version with the right nozzle size.
    • tsbservice
      Field tech
      • 8020
      #17
      1. This fits in place of toner filter not ozone(different sizes).
      2. Moreover even you can adapt it in some way to suck in place of ozone filter(low speed models 22-36 ppm) air paths(ventilation)are different and results will be close to zero.
      • John Kaufmann
        • Sep 2013
        • 115
        #18
        Thanks. Sorry for the confusion.
