C253 and C451 shows "!set up warning"
  • johnj_01201
    • 15
    Hello, we have 2 machines that show the main body status as "!set up warning" on the Pagescope web interface. Same place where it tells you the paper is out or low, it flashes in yellow "! set up warning".
    We do not know what this is and have not been able to find out any information about it.
    *These 2 machines have Fiery print controllers on them. Everything functions correctly and there is nothing on the copier display. The Fiery web page shows everything normally, no warnings.
    We had 1 other C451 that had a Fiery a few months ago and it does not show this warning message.
    The C253 was initially setup incorrectly by the tech and the whole procedure had to be redone because he got the grey background and didnt do the required setup steps in order. It has been working normally for about a month now and shows no problems.
    The C451 was setup by another tech and had no problems.
