Bizhub C658 Mac Sonoma Driver - Account Track Password Deletes
  • captainrva
    • Oct 2014
    • 100
    [Misc] Bizhub C658 Mac Sonoma Driver - Account Track Password Deletes
    Got a weird issue with one Mac Sonoma laptop (the other 4 work as they should). Reset printing system, installed latest driver, Save Account Track code under Output Method (after setting defaults in CUPS to account track on), Saved it as a preset, but every time this user prints...the account code has been wiped out. I set it to do Pop-Up code when printing and that setting deletes and just straight up doesn't work as well. Any help is appreciated.
  • Duplicator
    • May 2022
    • 255
    Have you tried setting the account track code and then saving the printer settings as a preset in macOS?
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • captainrva
      • Oct 2014
      • 100
      Hey, yes I have done that. Even with the code set and the preset saved...when you open the same document again, the code has disappeared even after reselecting the preset.
