FS-532 does not offset separate jobs?
  • Toxic
    • 697
    I have situation on C1085 and bizhub 1100, both with FS-532 when one job is printed finisher does not offset next job and it is a bit problem for customer to separate papers after printing several jobs without removing printed paper from finisher after every job.
    I search SM for some dipsw but did not find anything related to this.
    I think it must be some settings some where because i have few b950 and it offsets jobs without any special settings in driver.
    • 30188
    Re: FS-532 does not offset separate jobs?
    Check users settings
    • Synthohol
      Certified Konica Expert
      • 5822
      i think there is a setting for "continuous print" that can be [un]checked? also see if you can set the finisher to offset by default. <---maybe in the driver?
