printing error KONICA C308
  • Daniele
    • Jun 2019
    • 15
    Hello everyone,
    when I try to launch the print from pc, it shows this error "THE JOB HAS BEEN DELETED DUE TO
    INSUFFICIENT MEMORY"
    Can you help me please?.
    Thanks, in advance, regards.
  • Synthohol
    Certified Konica Expert
    • 5836
    print a config page, should show 4g memory.
    set spool print jobs to hdd in admin mode.
    double check driver, make sure set to IP and port 9100. and driver ver matches FW version.
    save the document to flash drive and see if you can print it from the panel.
    check HDD space, IIRC should be at least 170Gb vacant space
