C300İ Toner level not showing problem
  • Ghostlover34
    • Oct 2024
    • 15
    Hello Friends, Even though I put original toner in my printer, the levels are not visible. What could be the reason?
    This gallery has 1 photos.
  • tsbservice
    Field tech
    • 7924
    Can you print? No way all toners are empty at same time.
    Your firmware/function version are tool old or didn't match.
    • Ghostlover34
      • Oct 2024
      • 15
      The printer is working, all toners are full and original but the levels are zero. Which is the most trouble-free firmware for 300i that can fix this problem?
      Version 1.0
      Firmware : AA2J0Y0-0100-G00-G4(00)
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5740
        sent you a link for N4 firmware, good enough to set sw switch 25 to hex 20 for function ver 2.1
        • Ghostlover34
          • Oct 2024
          • 15
          Bro
          İnstall n4 Firmware
          C-C180 error code lodaeble driver error
          • tsbservice
            Field tech
            • 7924
            Do you have card reader?
            • Ghostlover34
              • Oct 2024
              • 15
              yes bro
              • Synthohol
                • Mar 2016
                • 5740
                those details would have been helpful first.
                some i series need the LDDs to be customized IIRC but depending on the accounting software used.
                i cant get you the latest base LDD but maybe someone here could.
                all im gonna mention is that sponsored members seem to get files faster from other sponsored members.
                seems to get attention from other members with KM access that take the time to download it and host on a file server somewhere at the risk of losing their job as it is legally prohibited to share software.
                i do have a shitload of LDDs but none less than 2 1/2 years old
                you are welcome to try them at your own peril, cant be any worse than coding out.
                LMK and ill send you the link.
                • Ghostlover34
                  • Oct 2024
                  • 15
                  okey bro thank you
                  I am ready to make any donation to reach them.
                  • Synthohol
                    • Mar 2016
                    • 5740
                    its not extortion bro, im most likely to point you to them regardless, just trying to keep the community strong.
