Bizhub C3850 Error Code 6790
  • shattered_dream
    • Jan 2022
    • 11
    [Error Code] Bizhub C3850 Error Code 6790
    Hello folks,
    I got this copier few days ago. While I scanned something yesterday, the printer suddenly lost power...
    After switching off and on again there is now the error code 6790... Can somebody help me verify what is defect?
    • 23003
    Re: Bizhub C3850 Error Code 6790
    The C6790 is a failure of the scanner to calibrate against the white level reference. There are several reasons why that might happen:
    * The scanner cannot reach the shading plate (there are two shading plates: one for the copyboard glass, and one for slit glass). If the scanner lock was ON, the scanner won't be able to move properly. Or the scanner belt might be broken.
    * The shading plate(s) might be dirty or missing.
    * The CCD may be reading the shading plate incorrectly.
    ... in that order. =^..^=
    • shattered_dream
      • Jan 2022
      • 11
      Forgot to write that I know that it is an error regarding scanner unit.... I already checked the search function....
      And got the service manual.... So how to begin ? Clean everything?
        BC laid out the order of the way to proceed.
        • shattered_dream
          • Jan 2022
          • 11
          Thanx! Sorry wrote my reply just before he posted...
            Ummm then why did your post show after his?
            • shattered_dream
              • Jan 2022
              • 11
              Sorry english is not my mother language.... Meant "hee posted while I was writing the reply...
              • Cantechman
                • Nov 2008
                • 228
                My guess is the scanner belt, it can be easily looked at. They break often.
                • shattered_dream
                  • Jan 2022
                  • 11
                  • Cantechman
                    • Nov 2008
                    • 228
                    Well then it's not the belt if it's moving unless it has missing teeth or something which is something I have never seen happen.
                    • shattered_dream
                      • Jan 2022
                      • 11
                      Good morning, problem solved... My wife had some sparetime while I was on work, so she opened the scanner, plugged CN102/CN103 off and on again, and the sacanner started working again... Thanks to all who helped...
