C-258, unable to load firmware...
  • rrrohan
    • Sep 2011
    • 1977
    #16
    Re: C-258, unable to load firmware...
    have you got the folder structure correct? (not sure if you have loaded KM firmware before not talking down to you)
    needs to be FW0002 in root directory then files. i used to make the mistake of putting files in the root instead of folder after years of working on 4 series and older
    • Oystercopy
      • Oct 2009
      • 623
      #17
      Yes, I stated above that I've done hundreds of F/W updates on these machines, and YES, the files are in the root of the drive.
      OC
      • tsbservice
        Field tech
        • 8020
        #18
        OC usb thumb drives sometimes crash all of the sudden. Did you make firmware update with this thumb on another machine?
